US
This Question is Answered
1 "correct" answer available (5 pts) 2 "helpful" answers available (3 pts)
10 Replies Last post: Nov 30, 2009 10:25 AM by Line6Miller
edbryan   3 posts since
Nov 9, 2009
Nov 19, 2009 10:27 PM
Using a Boss FV-500H pedal with the X3 Live
Was wondering how to calibrate this pedal when connecting it to the X3 Live. I connected it to the Pedal 2 Input as an expression pedal. The problem I'm having is the toe down position is minimum and the heel down position is maximum. How do I reverse this? Is this pedal compatible with the X3 Live?
Rowbi Guru 3,108 posts since
Nov 25, 2006
1. Nov 20, 2009 1:57 AM in response to: edbryan
Re: Using a Boss FV-500H pedal with the X3 Live
the only pedal that line6 support is the line6 EX1.  some other pedals do work, but it's pot luck.  if it doesn't work then calibrate it.  if it still doesn't work there's 2 options.  modify the expression pedal or buy another one.
the EX1 has a dual 20K pot inside I believe, with both pots in parallel, so this gives something very similar to a 10K Log pot in the EX1.
syd_barrett Juststartin' 25 posts since
May 6, 2009
3. Nov 20, 2009 8:32 PM in response to: edbryan
Good question! I'm waitin' for Rowbi to enlighten us on that one. A 4-star general must know how to calibrate an external expression pedal with the X3L
timowens Poweruser 595 posts since
May 14, 2007
4. Nov 20, 2009 9:01 PM in response to: edbryan
Isn’t it a sin to plug a Boss pedal into a Line6 product? Surely that would void the warranty at the very least!
Sorry, couldn’t resist
Nov 25, 2006
5. Nov 21, 2009 12:24 AM in response to: syd_barrett
lol, i feel a demotion coming on: http://line6.com/community/message/70969#70969
so the short answer is that if it doesn't work it's time to swap it for another one. sorry
Line6Miller Line6Support 7,456 posts since
Mar 28, 2006
6. Nov 23, 2009 11:06 AM in response to: edbryan
RE: Using a Boss FV-500H pedal with the X3 Live
Hello,
  As Rowbi mentioned, if the expression pedal you are using does not match the specs of the EX-1 then we cannot guarantee that it will work.
  If there is no way to calibrate the pedal then it sounds like that pedal is not compatible with the X3 Live.
  If all of your questions have been answered please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers, and close out the ticket as “answered” if your situation has been resolved. Thanks!
  Lien6Miller
Mar 28, 2006
7. Nov 25, 2009 9:40 AM in response to: edbryan
Hello,
  It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
  Line6Miller
Mar 28, 2006
9. Nov 25, 2009 11:15 AM in response to: edbryan
Hello,
  There is no external pedal calibration routine on the POD. You can only calibrate the on board expression pedal.
  Has this answered your question?
  Line6Miller
Mar 28, 2006
10. Nov 30, 2009 10:25 AM in response to: edbryan
Hello,
  Line6Miller
