JTV-59P-US Buy Now
James Tyler-designed Single-cut Guitar with Variax Modeling
Expertly crafted in the United States, JTV-59P-US places cutting-edge Variax® technology inside a classic tonewood combination established by the archetypal set-neck, single-cutaway solidbodies of the 1950s. The figured maple top is carved into a gentle arch and paired with a mahogany body and quarter-sawn mahogany neck. This combination of woods yields the full spectrum of warmth, depth, clarity and complexity that has made maple/mahogany construction legendary.
A pair of vintage-voiced P-90 soapbar pickups translates this guitar’s stunning tone to the amp of your choice. To complete the package, JTV-59P-US features a unique Tyler-designed, fully adjustable wraparound bridge (which redefines resonant coupling between strings and body); a supremely comfortable neck patterned after Tyler's own '59 neck shape, with a smoothly contoured heel; and jaw-dropping looks courtesy of five hand-sprayed finishes.
Head-turning Looks
The Extra Mile
