JTV-69S-US Buy Now
Expertly crafted in the United States, JTV-69S-US places cutting-edge Variax® technology inside a premium instrument designed in the image of the first successful solidbody electrics. The classic ash or alder body, quarter-sawn maple neck with rosewood or maple fingerboard, and 25-1/2” scale length provide tonal richness and warmth while preserving the design's historic bright, percussive snap.
To make the most of this stunning tone, the SSS pickup configuration features three ‘60s-style single-coil pickups loaded with alnico magnets and wound to James Tyler's specs. To complete the package, JTV-69-US features the comfortable Tyler ’59 neck profile; a James Tyler Custom Tremolo bridge; ultra-stable, quarter-sawn, three-piece maple neck; and jaw-dropping looks in your choice of classic and contemporary hand-sprayed finishes.
See Full Features
Head-turning Looks
The Extra Mile
