JTV-89F-US
JTV-89F-US
Expertly crafted in the United States, JTV-89F-US is an electric guitar of the highest caliber. This hard-rocking powerhouse marries incredible Variax technology with a sculpted mahogany body and a quarter-sawn, three-piece maple neck with 24-fret rosewood fingerboard.
A pair of custom, high-output, alnico humbucking pickups—wound to James Tyler's specs—translate this powerful instrument to the amp of your choice. The Floyd Rose® licensed, double-locking tremolo bridge by Graph Tech provides rock-solid tuning stability through massive pitch changes. Even with heavy distortion, the deepest lows and velvety highs emerge with exceptional definition.
*Floyd Rose is a registered trademark of Floyd Rose Industries.
“From what you see in the guitars, you can tell that everybody involved in the process cares about what they do.” —Tim Wilson
Before your James Tyler® Variax® US Custom Series guitar reaches your hands, it passes through those of the most skilled woodworkers, painters and builders in the business. Representing over a century of experience, the talented team demonstrates deep passion, pride and guitar players’ sensibilities while bringing James Tyler’s designs to life. By delicately balancing cutting-edge manufacturing technology with painstaking hand craftsmanship, the US Custom Series team creates instruments of incomparable beauty and feel.
“Beyond trying to satisfy the customers, I have to make sure that James Tyler will be happy… He holds extremely high standards for his work.” —Tim Wilson
“My philosophy is that there’s a right way to do things, and a wrong way. Pretty simple, do it the right way.” —Bruce Hamilton
“Without skill and expertise, you can turn that nicely machined part into firewood in a heartbeat.” —Jeff Callahan
Head-turning Looks
The Extra Mile
