Main :: StageScape M20d Mixer Community Support
Wifi Problem iPad 4
by HarryHae on 2013-04-18 13:45:54.3640
Hello
i have M20d and both dongles Samsung WIS12A and Linksys AE1000. can not connect my M20d with iPad4 , its a lucky change when it works, Samsung was a bit better, now after last OS-Update connection is impossible, does anybody have an idea, whats the problem?
iPad cannot find Wifi of M20d, sometimes its showed , but no connection! searching, searching,...
Thanks, Harry
Re: Wifi Problem iPad 4
by ArneLine6 on 2013-04-18 15:27:20.4390
Hi Harry,
Have updated the firmware on the M20d? The M20d and the iOS app need to be on the same version.
by line6jonb on 2013-04-18 15:49:33.8750
Instructions for how to update your StageScape M20d can be found at the following web address:  http://line6.com/support/docs/DOC-2832">http://line6.com/support/docs/DOC-2832">http://line6.com/support/docs/DOC-2832
Also, be sure to try different wifi channels on the StageScape, make sure you have a direct line of sight between your StageScape and your iPad.  Also, be sure that you do not have competing wifi routers within close proximity to your StageScape.
