Main :: Spider Jam
technical question -electrical glitch in Jam Song
by Philinwood on 2011-05-26 07:49:36.3780
on one song that is included in the playback jam songs already loaded into the Spider Jam, every 30 seconds approx. on playback the song just falters/stops for about a second or so and this electrical crackling sound happens-it sounds like an electrical glitch or like a short circuit type of sound just for a second.  So, I avoid this track because it doesn't sound like it is good for the amp, but can this be corrected?  I think it only happens on this one song.- Outlaw Country Club.
RE: technical question -electrical glitch in Jam Song
by Line6david on 2011-05-27 09:15:14.8180
Is the glitch on a song that you recorded or actually in the backing track it's self?
Have you tried transferring your songs to your computer and resetting the spider jam?
http://line6.com/community/docs/DOC-4778
http://line6.com/community/docs/DOC-4629
http://line6.com/community/docs/DOC-4499
Thanks,
David
Line 6 Customer Support
Re: RE: technical question -electrical glitch in Jam Song
by Philinwood on 2011-05-27 10:06:57.8300
the glitch  (it's like a static electricity charge type of sound) is on a pre-recorded jam track (specifically - "Outlaw Country Club" ) and it is NOT one of my recordings.  I did the factory reset procedure and therte was no change. It happens about everyuu 30 seconds- it is not subtle- it is very noticeable and sounds like the whole amp just shuts down for a millisecond and then it's right back to normal- for another 30 seconds until it repeats.
by mastermart on 2011-05-27 20:23:16.1020
its make the same glitch on mine too ??? what can i do to correct theproblem ??
thanks
by Philinwood on 2011-05-28 04:55:45.0990
does it happen on the same song on yours- "Outlaw Country Club?"
by mastermart on 2011-05-28 08:21:16.4250
HI Phil, yes the same song and its the same has you describe.did somebody help you with that ?? my spyder jam is one and half year old.
by mastermart on 2011-05-28 08:33:08.7380
Hi david,i have the same malfunction and its really inside of the preset song has phil describe to you so if we both have that problem you probaly heard about other that complaint about this ??
by Philinwood on 2011-05-28 10:20:57.9220
haven't heard anything yet- stay tuned
by Philinwood on 2011-06-01 06:17:56.5570
am I doing this right?  It seems so random.  I am sure this is not the first time Line6 has heard of this problem and another individual has posted that he is having the EXACT same problem.  How do you get the technical support to answer?  I hope it doesn't mean I have to get on the phone or write a letter.
I thought someone would have addressed this by now- it seems like they just want to avoid it.
by Philinwood on 2011-06-05 15:21:11.5060
Mastermart,  I just fixed it.  I downloaded and reinstalled the firmware even though I already had the most currewnt version it must have goten messed up.  So, when I downloaded and then installed it after deleting the old firmware it fixed the problem.
by mastermart on 2011-06-05 16:27:33.5500
Ok Phil, i will do this but can you tell me witch version did you download ??
Cool thanks
by Philinwood on 2011-06-05 17:33:02.3640
firmware version 2.09   it's the most recent version.  you have to have an SD card that is 2 GB or less, you have to format it  (sometimes formatting it multiple times is necessary and sometimes it seems to be most effective to format with the Spider Jam) and I think you need to have the firmware located in a file named Line6.
by mastermart on 2011-06-05 18:13:06.2340
Ok Phil, well done !!!!! COOL
by ryers on 2012-11-15 21:28:02.3940
This makes me feel really comforted since I'm not the only one with this problem. So I've tried the firmware solution but it didn't work I assume because i didn't use 2GB card or smaller so I'm going to try again following firmware install instructions to a tee and hopefully I have the same successful results as yourselves. Thanks.
