Main :: Spider Jam
Screech at start of loop
by lazysilverback on 2012-01-04 18:20:52.2400
I have a new Spiderjam unit with a weird problem... if I pick a drum beat and lay down a track on top of it, all is good.  If I then lay down a second track on that loop, when played back there is a momentary weird screech at the beginning of the loop; after that the loop sounds fine.
I thought maybe a firmware upgrade, but I checked and the firmware is current (DSP 2.09 / MCU 1.05)
Re: Screech at start of loop
by Line6david on 2012-01-11 17:11:06.2070
Have you tried a reset on the Spider Jam? Hold down the settings/tone button as you turn on the power and hold the button for 5-8 seconds.
Thanks,
David
Line 6 Customer Support
by lazysilverback on 2012-01-12 18:00:52.4480
I wound up flashing the firmware, which seemed to do the trick.
